Goes black when rendering
Operating system: Windows 10 Home
Graphics card: RTX 2070 SUPER
CPU: Intel Core i7-9700k CPU @ 3.60GHz
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Worked: last night (2-7-20)
Well I and not 100% sure if this is a bug or not but when I press render it looks as of it is going to render but when it is done it goes black.
Operating system: Windows 10 Home*
Can confirm, Eevee and Workbench cause the black screen, after a momentary render image. Cycles renders it (reduced samples to 4 for quick render) but displays the same black screen in the end as the other two. But don't take my word for it, there might simply be a wrong setting causing this.
Screen recording: F8330767
--debug-all : F8330773
related: T73655 [Eevee black screen on first frame]. CC: @Evan Wilson (EAW)
Operating system: Darwin-18.6.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) HD Graphics 6000 Intel Inc. 4.1 INTEL-12.9.22
version: 2.83 (sub 2), branch: master, commit date: 2020-02-07 22:49, hash: rBa010d9720455
Evan Wilson (EAW) closed this task as Archived.Feb 9 2020, 5:11 PM
Evan Wilson (EAW) claimed this task.
Thanks for the report.
I noticed that the combined pass under view layers displayed the doughnut and only the composite was black. Checked the compositor and found that the Render Layers node was not connected to the Composite node.
After connecting them together, everything showed up as it should.
@Ankit Meel (ankitm) T73655 might appear to be related due to similar titles, but that doesn't mean that they are caused by the same issue. The descriptions are also different. In T73655, only the first render is completely black after starting Blender. Subsequent renders are fine. Also the issue doesn't appear in 2.83, only 2.82. Merging a task as a duplicate is done for reports that have the same cause, not just similar titles. =)
