Circle Select Issues
Graphics card: Quadro P4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.30
Broken: version: 2.83 (sub 2), branch: master, commit date: 2020-02-10 13:21, hash: rBde09db6b4d13
Circle Select has issues with dense meshes. It appears that some vertices
{F8335562}on surfaces at glancing angles are obscured by others on the same plane. This makes it very difficult to create a complete selection without rotating the view...which can't be done in the circle select modal.
With a dense mesh:
  1. Enter Vertex Select in Edit Mode
  2. Use the circle select tool on a surface that is at a glancing angle to the view point. In the attached file, try circle selecting on the top face.
Selection quality is highly dependent on pixel density, so to reproduce the error, you may need to resize the 3d Viewport. My monitor resolution is set to 1920x1080. On a 4k monitor, the vertices would presumably be spread out more, and selection may not be effected. Likewise, the further out I zoom on the cube, the lower the selection quality is and even less vertices are selected.
This issue has been around since early alpha versions of 2.80.
Dan Pool (dpdp) added a comment.EditedFeb 12 2020, 12:16 AM
I know this cube looks like an extreme example, but it happens a lot when I'm working with hardsurface models with a lot of bevels and tiny screws. It is really fast to swipe arround the vertices you want to move on a hard surface model using circle select, but it's easy to miss vertices that were left out of the selection.
Click on the image for an animated gif that illustrates the issue.
This is unlikely to be resolved unless an entirely new selection method is used.
Documented this as a a known limitation rBM6207
