2.82 Freeze UI
Graphics card: GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 436.48
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
In some times Im using Blender 2.82 and for some reason just freeze it and I need to close and reOpen Blender to be able to use it
[Just Happend some times]
Ankit Meel (ankitm) closed this task as Archived.Feb 17 2020, 9:03 AM
Ankit Meel (ankitm) claimed this task.
It is highly vague statement to make: ".. for some reason ..". Please try to isolate the issue, make a screen recording just in case your workflow is getting tedious.
In the end, try to repro the bug with a simple blend file, and simple steps to repro.
Closing till then.
isolation can be done like, driver updates, factory settings, removing all addons etc
Ankit Meel (ankitm) added a comment.EditedFeb 17 2020, 9:04 AM
browse recent reports to see if you've been doing any of those steps. Search for rB77d23b0bd76f https://developer.blender.org/maniphest/query/JESP91pMhIO3/#R
Hi, I just want to add a note in case anyone else (like I did) finds this task while searching the web for help related to 2.82 UI freezing. I encountered some trouble with 2.82 and 2.83 in the last few days which sounds like it may be related. In my case the viewport choking and freezing my whole desktop was because I had not properly installed the latest nVidia drivers for my GTX 970.
Hope this helps someone.
