Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: 77d23b0bd76f, type: Release
build date: 2020-02-13, 01:56:46
platform: Windows
Worked: 2.81
This is a heavy issue for me, because I'm using the compositing every day and must go back to v 2.81 because of this one.
It's impossible to set a second fac keyframe for all nodes, where fac is implemented.
- Go to Compositing
- Create an image node and select an image sequence or set a single image to sequence
- Connect the image node to a mixer node (same with alpha blend etc.)
- Set a keyframe for a fac value
- Choose another frame and try set a second keyframe for the fac value
-> Not possible
Attached an example scene.
Open it and try to change the fac value for the mixer node.
