Macbook Pro 2012
Operating system: MacOS
Graphics card: None
2.82
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
When transforming (scale/rotate/translate) I MUST type in the correct axis FIRST before value e.g. S>x>4, R>z>15. I can’t toggle/change the axis after the value has been input like I used to. If I type in S>y>2 then want to switch it to instead scale upon the x axis I have to backspace everything making it hard to audition ideas within the workflow.
Open Blender. Either in Object or Edit mode transform the object along an axis a certain value e.g. s>x>4 then try to change the axis after this i.e. tap Y or Z. Nothing should happen but it will say Invalid in the upper bar.
