Bone constraints target misses eyedropper for subtarget bones
Operating system: Windows 10
Graphics card:
GeForce GTX 980 Ti/PCIe/SSE2
NVIDIA Corporation
4.5.0 NVIDIA 442.19
Broken: (example: 2.82, 7d23b0bd76f master, 2020-02-13
Worked: Riging
In the options of the bone constrains, the drop only selects the armature, and the bone must be searched among the list of bones. No exist drop selector bone.
Create armature and add constraint in a bone / use drop for select a bone / object armature is select and not exist drop for select a bone
Based on the default startup
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Feb 19 2020, 11:56 AM
1--In the options of the bone constrains, the drop only selects the armature, and the bone must be searched among the list of bones. No exist drop selector bone.
1-- create armature and add constraint in a bone / use drop for select a bone / object armature is select and not exist drop for select a bone
Not sure I understand correctly:
In this minimal example .blend I can select the armature and bone in the constraint:
Is this not working for you?
Please try to explain again what is missing for you or what the issue is (couldnt tell from the original report) and also provide an example .blend file along with it if neccessary.
2-- I also find that the multi selector "Alt" does not work on some options of bone constrains, for example the volume of strecht constraint ...
2-- select two bones and equal constraint configuration / press Alt and click in a button of constraint panel / has not change bones constraint property of all selected
Please dont mix multiple issues in a single report, please open up a new report for this...
Philipp Oeser (lichtwerk) renamed this task from constrains bones drop and multyselector to Bone constraints dropdown.Feb 19 2020, 11:58 AM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Hi Philipp, thanks for your attention.
In a Target select drop not include bone in the selection, and in a Bone selection not exist drop.
"Please dont mix multiple issues in a single report, please open up a new report for this..." Ok
Thx for getting back.
Now I get it, but I am afraid this will not be considered a bug.
Seems like the eyedropper is just not implemented for Bones. This could be a nice addition though.
Thanks again for the suggestion, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Philipp Oeser (lichtwerk) renamed this task from Bone constraints dropdown to Bone constraints target misses eyedropper for subtarget bones.Feb 19 2020, 3:57 PM
Philipp Oeser (lichtwerk) closed this task as Archived.
Ok, I will comment in Right click select.
thank's Philipp
