Alt+ clicking (assign to all selected) doesn not work for bone constraints settings
Operating system: Windows-10-10.0.10240-SP0 64 Bits
Graphics card: GeForce GTX 980 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
  • open file
  • two bones are selected (both having a copy rotation constraint), Bone constraints panel should be open
  • try Alt+click on any setting (e.g. X) of the copy rotation constraint --> setting will only be changed on the active bone
  • for comparison, there are also two cube objects (also having a copy rotation constraint)
  • try Alt+click on any setting (e.g. X) of their copy rotation constraint --> setting will be changed for both objects
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Feb 20 2020, 9:48 AM
Can confirm, checking...
Looks like this is true for all options on bone constraints?
Philipp Oeser (lichtwerk) renamed this task from multi selector bone restrictions does not work to Alt+ clicking (assign to all selected) doesn not work for bone constraints settings.Feb 20 2020, 10:03 AM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
@Richard Antalik (ISS): this doesnt seem to work in 2.79 either?
Anyways, I'll see if I can come up with something...
I checked this with limit scale modifier on maximum X field. It worked in 2.79
doesnt seem to work for me:
Alt+click on Maximum X field only changes it for one bone here...
Sorry, I did extrude second bone, so both were affected when I tested this. I should have looked at actual values not only at result visually...
