Blender 2.82 Crash when baking particles
Operating system: WIndows 10
Graphics card: RTX 2070 + GTX 1060
Broken: Blender 2.82, release, 29.02.2020
When I press bake particles to bake the particles for Spray, Foam and bubbles blender crashes, almost instantly.
Scroll down to particles and press bake
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Mar 2 2020, 5:00 AM
This file takes quite long to bake, can it be simplified?
I was able to cause crash by baking to frame 10, change range and resuming baking, is that by chance what you did?
Hi thanks for replying, in my case when I press bake, Blender crashes immediatly, it only crashes when I make bigger Projects, like this one.
Can you manually delete cache folder and try baking again?
Thanks for the report. If the problem persists please open a new report with the required information.
Tora Stiefel (TORA) changed the task status from Archived to Resolved.Dec 13 2021, 11:07 PM
I have also this crash when baking particles. Using Blender 2.9, 3.0.0.
Using MacBook Pro Mojave
