Mac OS draws object made from only vertices differently from Windows (object 'Display as' mode set to 'WIRE').
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.82 (sub 6), branch: master, commit date: 2020-02-11 14:45, hash: rBc939b4df18e9
Scene has cube mesh object - with edges and faces removed (only vertices are left). In object mode vertices will be visible as points, but if I want to hide them I can set object 'Display as' mode to - 'WIRE' then:
  • for Windows users - object vertices are no longer visible (nice)
  • for Mac users object vertices remain still visible (not good)
Hopefully this can be unified to hide drawing of verts in object mode and 'WIRE' draw method for both OS.
  • add cube - delete only edges and faces
  • set object draw mode (in object 'Viewport Display' props - to 'WIRE'. On Mac OS vertices remain visible.
I attach blend with hidden cube vertices in object mode.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.EditedMar 5 2020, 12:50 PM
In my opinion a mesh with only looseverts should be visible in both solid mode and wireframe mode.
This is how it worked in blender 2.79.
I don’t know why you say it’s not good to remain visible. The problem here seems to be on Windows and not on Mac.
@Clément Foucault (fclem), do you know if you had a decision on how it should be?
Hiding verts by setting object 'Display as' WIRE in just nice option to have, IMO better to have 2 options, rather than make verts always visible.
In my case I want to be able to snap to invisible verts using build-in blender vert snapping tools, while I'm drawing them in python using BGL. But yep, you may say it is actually bug- and that they are should be always invisible - it is just nice trick to have (hiding verts by drawing object as wire)
@Germano Cavalcante (mano-wii) I don't remember any decision on this. It might be a bug. They don't show here either on linux.
In my opinion the correct thing should be to follow what it was in 2.79.
So that should solve:
diff --git a/source/blender/draw/engines/overlay/overlay_wireframe.c b/source/blender/draw/engines/overlay/overlay_wireframe.c
index 5dbdc71dae1..592542bd723 100644
--- a/source/blender/draw/engines/overlay/overlay_wireframe.c
+++ b/source/blender/draw/engines/overlay/overlay_wireframe.c
@@ -129,8 +129,10 @@ void OVERLAY_wireframe_cache_populate(OVERLAY_Data *vedata,
   const bool all_wires = (ob->dtx & OB_DRAW_ALL_EDGES) != 0;
   const bool is_xray = (ob->dtx & OB_DRAWXRAY) != 0;
   const bool is_mesh = ob->type == OB_MESH;
-  const bool use_wire = (pd->overlay.flag & V3D_OVERLAY_WIREFRAMES) || (ob->dtx & OB_DRAWWIRE) ||
-                        (ob->dt == OB_WIRE);
+  const bool is_mesh_verts_only = is_mesh && (((Mesh *)ob->data)->totedge == 0 &&
+                                              ((Mesh *)ob->data)->totvert > 0);
+  const bool use_wire = !is_mesh_verts_only && ((pd->overlay.flag & V3D_OVERLAY_WIREFRAMES) ||
+                                                (ob->dtx & OB_DRAWWIRE) || (ob->dt == OB_WIRE));
   if (ELEM(ob->type, OB_CURVE, OB_SURF)) {
     OVERLAY_ExtraCallBuffers *cb = OVERLAY_extra_call_buffer_get(vedata, ob);
@@ -221,7 +223,7 @@ void OVERLAY_wireframe_cache_populate(OVERLAY_Data *vedata,
     DRW_object_wire_theme_get(ob, draw_ctx->view_layer, &color);
     /* Draw loose geometry. */
-    if (me->totedge == 0 && me->totvert > 0) {
+    if (is_mesh_verts_only) {
       struct GPUBatch *geom = DRW_cache_mesh_all_verts_get(ob);
       if (geom) {
         OVERLAY_extra_loose_points(cb, geom, ob->obmat, color);
But it's strange that on the Mac the drawing behaves differently.
@Ankit Meel (ankitm) or @Brecht Van Lommel (brecht), can you confirm that behavior on Mac?
tested on 2.83 rB3da2dc82132f downloaded from https://builder.blender.org
