Video Sequencer: The Blend Factor in Color Mix strips is broken.
Closed, DuplicatePublicBUG
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 600 Intel 4.5.0 - Build 26.20.100.7262
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
The Blend Factor in Color Mix strips has no effect.
  • Add two strips to the sequencer.
  • Select them both.
  • Add a Color Mix effect strip.
  • In the sidebar, change the Blend Factor.
  • Nothing happens.
This is a bug, as this function is supposed to set the amount of how much influence either input should have.
(On the same note: Sidebar > Adjust > Composite > Blend Modes are completely missing the Blend Factor)
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Mar 4 2020, 5:44 PM
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Bug".
Seems like blend_color_add_float expects 'control' alpha in second input, while blend_color_add_byte expects it in first input.
A comment on the merge: while this is similar to T76376: VSE Opacity Not Working With Certain Blend Types, there's one difference: you don't have to add a Color Mix effect strip, the issue also affects the regular blending of two movie/image strips for the 18 blend types I mentioned. Then again, the underlying cause may very well be the same.
Peter Fog (tintwotin) closed this task as Archived.Jun 9 2020, 8:32 AM
Peter Fog (tintwotin) claimed this task.
Not sure why this was closed?
This still seems broken and was reported again in T79333: Some Blend mode opacity in VSE (Video Sequence Editor) cannot adjust opacity.
Can only imagine this being a duplicate of T75844: Blend modes are broken?
