Transparency and Emission Does not Render Correctly on Transparent Background
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
When rendering an emissive transparency on top of a transparent background (either Eevee or Cycles) the transparent object's material color becomes completely desaturated. This only happens in the render (F12) not in the viewport camera.
In Render Properties, go to Film and turn on Transparency.
Create a sphere, add a mix shader with transparent and emissive and make it mostly transparent to see the results better (Factor of .05 or so).
Crank the emissive node up to maybe 50 and give it a color 1,0,0 for pure red.
In viewport camera, you see what you would expect, a red-ish emissive sphere with some transparency. When rendered however, the sphere will be almost completely desaturated of color.
Turn on bloom in Eevee to get the effect even more.
In the viewport, you will see the bloom and it look as it should but when rendered, no bloom and no color.
In this image, the left version is rendered with a transparent background and composited in, the right is rendered with the background in place (no alpha).
https://imgur.com/a/3swdIuf
The image in the link above.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Mar 5 2020, 4:10 AM
Can you please upload simple .blend file demonstrating this?
Based on the description this could be a duplicate of T52680
Yes, it's the same issue as T52680: Alpha difference Viewport/F12 .
In general if you want to use that image for compositing in other software, you need to save it in a file format like OpenEXR which supports emission without opacity, which e.g. PNG does not support.
Thank you! Yes, the OpenEXR works perfectly. Just have to Gamut back to sRGB.
