Grease Pencil: Objects clip into polygons
Operating system: MacOS Sierra Version 10.12.6, MacBook Pro (15-inch, Late 2011), 2.4 GHz Intel Core i7 Processor, 16 GB 1333 MHz DDR3 Memory
Graphics card: AMD Radeon HD 6770M 1024 MB, Intel HD Graphics 3000 512 MB
Broken: v 2.82
Worked: N/A
I'm not sure if this is a bug or a known issue, but Grease Pencil objects are clipping through polygons with little to know effort. It makes sense if the Grease Pencil object is flush with the surface of a polygon, but it seems to clip into the object if I zoom the camera a distance. It seems to occur when I set the Stroke Depth Order to 3D Location.
  1. Create any sort of CGI model and then a Grease Pencil object.
  2. Once you draw on the surface of the object (a little offset is recommended), go into Object Data Properties > Strokes. From there, set the Stroke Depth Order to 3D Location.
  3. Zoom out with the camera and you'll see the result.
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Needs Information from User.Mar 10 2020, 4:13 PM
Could you test the last daily build?
What do you mean by the last daily build? Do you mean the official stable version or the experimental version? I checked the site and it stated this:
"Blender 2.82 was released on February 14, 2020"
I already downloaded a new version of Blender from last night, so have you fixed the bugs and replaced the download just now?
EDIT: Seems that I found the page that has the daily builds. While there is a beta for 2.82a, the page warns me that they are likely unstable and I should use them at my own risk.
I mean the 2.83 version. The last Monday (March 9th) we merge a full refactor of the grease pencil drawing engine to solve all issues like this, so try to test the daily build (2.83 Alpha).
Okay, I carefully tried the new experimental version of Blender. While the last 2.82 build provided unchanged results, the 2.83 version worked extremely well! Even the new features caught my eye!
All the same, though, I'd rather not touch this version until the official one "hits the market." I don't want my files getting corrupted or worse.
Ankit Meel (ankitm) closed this task as Resolved.Mar 18 2020, 8:41 PM
Ankit Meel (ankitm) claimed this task.
Nice!
