Grease Pencil objects not reacting to lights
Operating system: OSX High Sierra
Graphics card: AMD Radeon R9 M370X 2 GB / Intel Iris Pro 1536 MB
2.83 Alpha
Date 2020-03-12 19:47
Hash: fa823f0af867
When adding a light to the scene, the grease pencil objects don't react to it.
  1. Open new 2D Animation file
  2. Select the Grey "Solid Fill" material.
  3. Draw a shape.
  4. exit into Object mode
  5. Add a Light. (and orient it to object depending on light selected)
ronsn added a subscriber: ronsn.EditedMar 12 2020, 11:16 PM
@Berbank Green (Berbank) Did you try to give your light source a higher Power (Watt)?
Edit: Light reacts to Suzanne (with 1000 Watt) but not for own drawings.
Confirmed. Light works with Suzanne (but not all the time) and doesn't with my own grease pencil objects.
The way I've done it in the original post it doesn't work.
However if you:
  1. Start a General scene
  2. Delete cube
  3. Add GP Suzanne
The light works and additional GP objects also seems to work.
This comment was removed by Berbank Green (Berbank).
Be sure of these:
  1. GP Object must have enabled lighting (see Object properties in properties panel). For old files this can be disabled.
  1. Layer must be enabled for lighting. For old files this can be disabled.
  1. Your shading mode must be Render:
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Needs Information from User.Mar 13 2020, 11:54 AM
@Antonio Vazquez (antoniov) I had missed the one needed in the Object properties but got the other ones.
Thank you, all works with both Object and Layer lighting enabled.
Antonio Vazquez (antoniov) claimed this task.
