Artifacts in solid view
Closed, ResolvedPublicBUG
Operating system: Linux-5.4.24-1-MANJARO-x86_64-with-glibc2.29 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.4.24-1-MANJARO, LLVM 9.0.1) X.Org 4.5 (Core Profile) Mesa 19.3.5
Broken: version: 2.83 (sub 9), branch: master (modified), commit date: 2020-03-15 18:43, hash: rB22925d0dd31e (Master is modified because I had to revert commit 56d6666689f7 because of https://developer.blender.org/T74024 it also show artifacts without the revert), blender-2.83-a210b8297f5a-linux64
Worked: 2.82 official, version: 2.82 (sub 6), branch: master, commit date: 2020-01-14 15:55, hash: rBba5bbf14f92b, 2.83 56d6666689f7
There are artifacts on the geometry in solid shading (can't see them in the other modes). On a different system with intel skylake with integrated graphics, the artifacts are not visible.
Open blender, rotate camera around default cube until you see the artifacts (in the default view position it is not very visible. It helps to move closer to the cube and to look at the brighter areas)
As mentioned in the ticket this could be related to T74024: Faces missing, weird faces added
Biggest challenge of this ticket is that we cannot reproduce this with the hardware we have. But as it has worked for some releases.
It would help us to perform a git bisect or check with renderdoc on this issue; would that be something you could help us with?
Found it! This commit also caused the crash opening the Spring splash scene https://developer.blender.org/T74791
c476c36e400883d929a7149def8dcb6ad6157a86 is the first bad commit
commit c476c36e400883d929a7149def8dcb6ad6157a86
Author: Clément Foucault <foucault.clem@gmail.com>
Date: Wed Mar 11 17:07:43 2020 +0100
Workbench Simplification Refactor
This patch is (almost) a complete rewrite of workbench engine.
The features remain unchanged but the code quality is greatly improved.
Hair shading is brighter but also more correct.
This also introduce the concept of `DRWShaderLibrary` to make a simple
include system inside the GLSL files.
Differential Revision: https://developer.blender.org/D7060
@Georg K (georg) Thanks, That is a big patch. @Clément Foucault (fclem) do you have an idea what could corrupt this on old AMD cards?
I've noticed similar artifacts in wireframe view on my system (Win 10, 2600X, RTX 2060 442.59), so this might not be hardware/driver specific.
No artifacts in wireframe view here.
@Georg K (georg) we need a bit more testing: does that happen with all shading mode? color mode? with outline enabled? with cavity enabled? etc...
Is there any configuration (which is not Xray or wireframe) that works?
Georg K (georg) added a comment.EditedMar 17 2020, 3:39 PM
There is a configuration that works: Specular Lighting: off removes the artifacts. There is also a slight improvement by setting Antialiasing >= 5Samples as long as there is no interaction.
Also, setting Specular Lighting to "off" and deactivating "Load UI" in the file view allows to load the Spring splash scene https://developer.blender.org/T74791 without crashing.
tested cases in detail:
Viewport Antialiasing off/Single Pass Antialiasing: artifacts in both cases
Viewport Antialiasing 5Samples - 32Samples : artifacts in all cases,
But: with higher sample count, artifacts vanish if the view is not moved (looks like blurring). Once the camera is moved, they become visible again and flicker as long as the viewport is interacted with. The pattern also changes if a different tool is selected or while the cursor is moved over the navigation gizmo.
Overlay Smooth Wires on/off: artifacts in both cases
Edit Mode Smooth Wires on/off: artifacts in both cases (does not seem to have any effect on wire smoothness in edit mode in contrast to Overlay Smooth Wires. Edit mode wires always seem smooth)
Shading mode?
wire : -
solid : artifacts
material: -
rendered: -
Solid shading - Viewport shading: Color=Material/Object/Vertex/Single/Random/Texture: artifacts in all cases
Background Theme/World/Viewport: artifacts in all cases
Options:
Shadow on/off: artifacts in both cases
Cavity on/off: artifacts in both cases
Outline on/off: artifacts in both cases
Specular Lighting on: artifacts
Specular Lighting off: no artifacts
Clément Foucault (fclem) changed the subtype of this task from "Report" to "Bug".Mar 23 2020, 6:18 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Mar 24 2020, 2:36 PM
Retested rB22925d0dd31e after mesa upgrade from 19.3.5-1 to 20.0.4-1 and the artifacts are gone.
Georg K (georg) closed this task as Resolved.Apr 15 2020, 6:44 PM
