Visual glitches with Single Color shading
Operating system: win 10
Graphics card: rx590
Blender Version (2.8- to 2.3 is the same)
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Worked: Never
i have a issue with the MATCAP menu when i choice SINGLE mode! the graphics crash! the only good notices is that only happens in these mode, the other modes
works fine!
Steps to reproduce
  1. Open General template
  2. Click on Viewport Shading options
  3. Choose Flat Lighting
  4. Choose Single Color
This is the result:
Evan Wilson (EAW) changed the task status from Needs Triage to Needs Information from User.Mar 19 2020, 6:37 AM
That looks like a driver issue. Please try updating your driver.
https://www.amd.com/en/support/graphics/radeon-500-series/radeon-rx-500-series/radeon-rx-590
Could you please also open the help menu in Blender and select "Save System Info." Then upload that file here. I want to see if Blender is using the dedicated GPU or the in built one on your CPU.
thanks! i refresh my drivers with the news last, and the olds!:P i try a test with cpu, and then gpu, and is the same!:O all the others modes works fines! and it is nice!:O but i wan try single to do blue with white lines, i can´t understud how blender can´t run it!:O
I meant upload the file, not paste the text. If you could edit your post by deleting the text and uploading the file, that would be appreciated.
From reading the text, I see that Blender is using your GPU so that is good. Is it only this file that has this issue, or is it any file?
Can you also try using the latest daily build?
https://builder.blender.org/download/
Sorry! for it!;D but i notice the web code, frame the text! i do the test wiht only cpu and only gpu, i do the test with the simple cube escene and is the same!? i do the test in the 2.8 2.81 2.82 and 2.83, is it somehting about the drivers actualization, i never noticed it, is the firt time i play with it, but is only me, must be something between the graphic and the cpu!?:O yo can do it!?
Ankit Meel (ankitm) renamed this task from Hi! i have a issue with the MATCAP menu whe i choice SINGLE mode! to issue with the MATCAP menu when I choose single mode.Mar 19 2020, 8:18 AM
Ankit Meel (ankitm) updated the task description. (Show Details)
Please remove that system info comment, I've added it to the task description.
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.Mar 21 2020, 9:27 AM
Richard Antalik (ISS) renamed this task from issue with the MATCAP menu when I choose single mode to Visual glitches with Single Color shading.Mar 23 2020, 12:57 PM
Richard Antalik (ISS) updated the task description. (Show Details)
Could you provide a simple file with the settings already set?
I can't reproduce the problem.
Through sistem_info.txt I could see that the driver really seems to be updated.
My pc specs:
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13586 Core Profile Context 19.50.01.05 26.20.15001.5006
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Apr 1 2020, 6:47 PM
whell! now i see when i mark the option "shandows" can work fine!:)
I assume this means this is no longer an issue?
Thanks for the report. If the problem persists please open a new report with the required information.
