Graphics card: GeForce MX150/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.75
Broken: version: 2.83 (sub 11), branch: master, commit date: 2020-03-24 23:23, hash: rB188ccfb0dd67
Worked: never
Blender Crashes while baking dynamic paint if liquid simulation is used as a brush. If you use a plane or a cube as a canvas and priviously midified it with sculpting -> dyntopo enabled the baking makes blender crash. Once you set up everything and click bake on the dynamic paint the cpu will be of maximum usage and the process bar stops at 2% and then crashes after a while. No image will be baked.
Also testet on Windows 10 with Intel i7 6700K and NVIDIA GTX 970 same result (Blender crashed)
Interstlingly enough, it seems to work normal if the dyntopo isn't used and it was just modified with the normal brushes. Maybe the extra geometry added with dyntopo caused the crash.
Open attached blend.file
Bake the Liquid Simulation
Go to the Plane and to the dynamic paint setting and click bake image sequence
Thanks!
