Operating system: Windows 10
Graphics card: nVidia GTX 970
Broken: 2.82
Worked: No idea.
- Add a NURBS curve.
- Edit mode.
- Select all (or one) vertex.
- Control Points -> Set Handle Type -> Vector
- Nothing happens.
According to the internet it should make the vertices sharp instead of smooth. The documentation also says it should do this: https://docs.blender.org/manual/en/latest/modeling/curves/editing/control_points.html#set-handle-type
Edit: It seems like it isn't supposed to work on NURBS, but then the UI should either hide the option when you are editing NURBS, or give you an error if you try to use it on a NURBS object.
