Exporting gltf results in numpy error, unable to load multiarray
Operating system: Ubuntu 18.04
Graphics card: NVIDIA GTX 1050, drivers 440.64
Broken: 2.83, sub 11
Worked: unknown
export as gltf results in error. numpy is unable to load multiarray.
  1. open blender with new file (e.g. just a cube)
  2. Export as gltf
  3. Click Export / Save File <--- error occurs here
I've tried uninstalling numpy & reinstalling it with apt pip and conda. No change in the error. reboots dont affect.
Cannot redo on rB10bd3fb4cb186f927d8839d2da28eeb90d6722f3
Operating system: Darwin-18.7.0-x86_64-i386-64bit 64 Bits
'Blender.app/Contents/Resources/2.83/python/lib/python3.7/site-packages/libextern_draco.dylib' exists, draco mesh compression is available
07:02:17 | INFO: Starting glTF 2.0 export
07:02:17 | INFO: Extracting primitive: Cube
07:02:17 | INFO: Primitives created: 1
07:02:17 | INFO: Finished glTF 2.0 export in 0.00869297981262207 s
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.EditedMar 28 2020, 8:05 AM
Please add the full error. Run ./Blender --debug-all > T75152.txt and upload the file
I apologize, i am new to blender, and relatively new to linux. Where am I executing the command from? Below is the error message.
{F8432139}Blender Info Log:
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 16, in <module>
    from . import multiarray
ImportError: cannot import name 'multiarray' from 'numpy.core' (/usr/lib/python3/dist-packages/numpy/core/__init__.py)
During handling of the above exception, another exception occurred:
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/__init__.py", line 391, in execute
    from .blender.exp import gltf2_blender_export
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_export.py", line 22, in <module>
    from io_scene_gltf2.blender.exp import gltf2_blender_gather
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_gather.py", line 19, in <module>
    from io_scene_gltf2.blender.exp import gltf2_blender_gather_nodes
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_gather_nodes.py", line 22, in <module>
    from io_scene_gltf2.blender.exp import gltf2_blender_gather_skins
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_gather_skins.py", line 22, in <module>
    from io_scene_gltf2.blender.exp import gltf2_blender_gather_joints
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_gather_joints.py", line 21, in <module>
    from io_scene_gltf2.blender.exp import gltf2_blender_extract
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/blender/exp/gltf2_blender_extract.py", line 25, in <module>
    from ...io.com.gltf2_io_color_management import color_srgb_to_scene_linear
  File "/usr/share/blender/2.83/scripts/addons/io_scene_gltf2/io/com/gltf2_io_color_management.py", line 15, in <module>
    import numpy as np
  File "/usr/lib/python3/dist-packages/numpy/__init__.py", line 142, in <module>
    from . import add_newdocs
  File "/usr/lib/python3/dist-packages/numpy/add_newdocs.py", line 13, in <module>
    from numpy.lib import add_newdoc
  File "/usr/lib/python3/dist-packages/numpy/lib/__init__.py", line 8, in <module>
    from .type_check import *
  File "/usr/lib/python3/dist-packages/numpy/lib/type_check.py", line 11, in <module>
    import numpy.core.numeric as _nx
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 26, in <module>
    raise ImportError(msg)
ImportError:
Importing the multiarray numpy extension module failed.  Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control).  Otherwise reinstall numpy.
Original error was: cannot import name 'multiarray' from 'numpy.core' (/usr/lib/python3/dist-packages/numpy/core/__init__.py)
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.Mar 29 2020, 10:24 AM
Ankit Meel (ankitm) edited projects, added Import/Export, Python API; removed BF Blender.
It seems you are using a custom Blender build. The error happens because it is building with incompatible Python and numpy, where the numpy library was compiled against a different Python version. See for example:
https://github.com/domlysz/BlenderGIS/issues/225
https://github.com/numpy/numpy/issues/14796
We recommend following the Quick Setup with precompiled libraries for building, which should avoid the issue:
https://wiki.blender.org/wiki/Building_Blender/Linux/Ubuntu
If you need to build against system libraries, this kind of configuration issue is not something we can fix in Blender.
