Boolean is not working as expected
Operating system: Linux-4.15.0-91-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce 940MX/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.81 (sub 16), branch: master, commit date: 2019-12-04 11:32, hash: rBf1aa4d18d49d
I have array of objects. And i want to give scroll effect. Now when i use cube on it to display only overlapping objects it show only one which come fully under it. Like if i scroll and half box from it go out it will remove whole object. In ideal case it must show half of that object.
  1. Create a cube (representing post on the mobile screen)
  2. resize it
  3. Add array modifer
  4. Create new cube
  5. overLap it on arrays of cube(post)
  6. Select Post array and then add boolean modifer
  7. then intersect ( in boolean modifer )
  8. It only showing post which come fully inside it
It was working. Then i shut down my system and next day it show this error
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.Apr 1 2020, 1:43 PM
  • Please add a simple blend file to help redo the bug.
Also, just for reference: https://docs.blender.org/manual/en/latest/modeling/modifiers/generate/booleans.html
Added the files
PLease check
Will this get resolved ?
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.Apr 2 2020, 8:48 AM
Ankit Meel (ankitm) added a project: Modifiers.
The author can get the desired behavior it he put the "Bevel modifier" at bottom after the "Boolean modifier".
Also the "Posts" need apply scale and merge, this will fix the problem too.
I guess it is not a bug.
I just uploaded the list of modifiers. May b this can help
Hey here you see the error much more clearly. I did scale it down also but results were same
From the attached file, what should I do to reproduce the problem?
There are many boolean-related bugs.
Probably the bug here has already been reported in a more specific way.
And from @Rigoletto Eikenberg (rigoletto) comment, the way the modifier is being used is not appropriate.
Thanks for the report. Unfortunately the scenario described is too time consuming for us to track down, we require the bug reporter to narrow down the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
