Modifiers added in edit mode are undone out of order if you go back to object mode
Confirmed, NormalPublicKNOWN ISSUE
Graphics card: GeForce GTX 1070 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.66
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-08 21:23, hash: rB1239cab11ff9
Worked: Never (2.8+)
Modifiers added in edit mode are undone out of order if you go back to object mode and then start undoing.
Affects both old and new undo system. There's often mentions of edit<->object transitions being problematic but just in passing; I think this is a long standing issue. Just wanted to note it down as I test out the undo systems.
Hoping the new undo system can account for this now.
  • Default scene
  • Go to edit mode on the default cube
  • Add any modifier (bevel, subdivision, etc.)
  • Add any loop cut 1
  • Add another loop cut 2
  • Go to object mode
  • Undo --> Modifier is removed first (out of order)
  • Undo --> Loop cut 2 is removed
  • Undo --> Loop cut 1 is removed
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Apr 13 2020, 7:58 PM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Apr 22 2020, 4:56 PM
Bastien Montagne (mont29) added a project: Restricted Project.Jun 24 2021, 12:39 PM
Bastien Montagne (mont29) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Jan 27 2022, 5:58 PM
