Broken: 2.82
Worked: Since Ngons Feature
When you have a single edge that's not connected to a face, you can subdivide it (inserting vertices) with Loop Cut (Ctrl+R),
this shows a yellow dot/gizmos that shows you where the vertices are being inserted and how many,
when you try to do this when an edge is part of a face, you can still insert a vertex and many vertices, but it doesn't show the yellow dot.
(I know the Ctrl+R tool is called Loop Cut, but it would be nice if depending on your selection mode, you can insert vertices, add edge loops, or subdivide faces with it.)
- Open Attached file
- Loop Cut (Ctrl R) on the loose edge (See the dots)
- Loop Cut (Ctrl R) on an NGon edge (where are the dots?)
