Grease Pencil doesn't work with sculpt mode
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.83 (I only test this two version 03/04,13/4(the newest) build) commit date: 2020/4/13, hash: rBunknown
Worked:
work with the 2.82a stable
Grease Pencil doesn't work properly in sculpt mode in a already existing file(with the new grease pencil object add),
1.when creating a new file ,selecting with 2d animation , the sculpt mode work well with the first grease pencil
2.but for the next grease pencil object ,it cannot use the sculpt mode(the brush doesn't affect it )
3.worst,you add a grease pencil in a existing file ,you can't even see the size of the sculpt brush
same question 2 weeks ago in community https://blender.community/c/today/BYdbbc/
build with 2d
build with empty normal ,then add new object
THANKS!
Antonio Vazquez (antoniov) changed the task status from Needs Triage to Needs Information from User.Apr 13 2020, 7:17 PM
I cannot reproduce with 2.83. How are you setting the mode? are you using the Outliner? Maybe your object is not in sculpt mode.
I add a short video to show the problem
I can see your sculpt brushes are damaged. I fixed the bug a few days ago in the default template.
try to reset the brushes using the reset all.
Also, be sure to use the last build of 2.83.
EDIT> I have tested with the very last source code compiled by myself just a few minutes ago.
More than a week without reply or activity.
Due to the policy of the tracker closing for until required info/data are provided.
If the problem persists please open a new report with the required information.
