tablet navigation problems with blender 2.83a
Closed, ResolvedPublicTO DO
Operating system: win 10 build 18363
Graphics card: icelake 1065G7 *(G7 is the name of the integrated graphics)
Broken: 2.83a,
Worked:2.82
in a new blender file or any blender file when you navigate using touch controls (via tablet pro Artist Pad) the new touch/mouse pointer handling is superseded by the pen pointer information. This breaks the navigation process for tablet users using Tablet Pro Artist Pad.
please watch this video
https://youtu.be/Ru_LfQCjt7c
when using 2.83a the navigation by the artist pad is constantly interrupted by the pen and it jumps around and the pen needs to be moved away from the screen. It worked MUCH better in 2.82
the best solution in my opinion is to work on updating the touch api used by blender to the newer one provided by microsoft. This would allow for perfect navigation even better than the current v2.82 version
please reach out to me
i believe that Brecht Van Lommel would know how to fix this
justice@tabletpro.com
Justice
The cause of this is a dup of T75566, the rollback that fixed that should have fixed this.
I'll have to think a bit more on how to correctly handle this case; thank you for the video demonstrating the problem.
Bastien Montagne (mont29) changed the task status from Needs Triage to Confirmed.May 20 2020, 11:57 AM
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "To Do".
Marking this resolved as it was fixed by rolling back previous changes, but feedback is still necessary to ensure this does not return when D7840 lands.
Nicholas Rishel (nicholas_rishel) added a project: Restricted Project.Oct 19 2020, 9:12 PM
Nicholas Rishel (nicholas_rishel) moved this task from Restricted Project Column to Restricted Project Column on the Restricted Project board.Oct 19 2020, 9:14 PM
