Annotations: KeyFrames not showing for 3d animation
Operating system: Windows 10
Graphics card: Geforce GTX 1050 TI
Broken: ( 2.83.13, , master, 2020-04-25)
Worked: (2.82.7)
Grease Pencil Animation keyframes are not showing in 2.83
Based on attached .blend file, Click on Animation Tab and choose Grease pencil on Bottom Menu. I have added 2 keyframes for grease pencil which is visible in 2.82 but not visible in 2.83.
Antonio Vazquez (antoniov) claimed this task.
This is not a bug.
If you look at your sample file, you are using annotations, not grease pencil, and also you have enabled only selected. In 2.82 the only selected had a bug a show all annotations if you had this button enabled and this was wrong. To see your annotation keyframe, just uncheck the button.
Antonio Vazquez (antoniov) renamed this task from Grease Pencil Animation KeyFrames not showing for 3d animation to Annotations: KeyFrames not showing for 3d animation.Apr 25 2020, 10:47 AM
Yes..that seems likely to be the case. Thank you for clarification.
