Operating system: Win10
Graphics card: Nvidia GTX 1060 6G
Broken: 2.82
Worked: None
Cannot use keyframes, File select, File picker (eyedropper), etc. in modal Operators/Panels called by WindowManager
For example, this is an operator called by WM to manipulate the location of the selected object. We cannot insert keyframes to the property from RMB > Insert Keyframe or from the anim dot after the property
import bpy
class HelloWorldOperator(bpy.types.Operator):
"""Creates a Panel in the Object properties window"""
bl_label = "Hello World Modal Operator"
bl_idname = "test.hello"
def draw(self, context):
layout = self.layout
layout.use_property_split = True
layout.use_property_decorate = True
obj = context.active_object
layout.label(text="Hello world!", icon='WORLD_DATA')
layout.prop(obj, 'location')
def execute(self, context):
return {'FINISHED'}
def invoke(self, context, event):
wm = context.window_manager
return wm.invoke_props_dialog(self)
def register():
bpy.utils.register_class(HelloWorldOperator)
def unregister():
bpy.utils.unregister_class(HelloWorldOperator)
if __name__ == "__main__":
register()
bpy.ops.test.hello('INVOKE_DEFAULT')This kind of problem exists in all modal-like panels or operators called by WM. The file picker from file_select is also not working. Is it RNA problem? I hope developer can generate its error message in the console. For now, I don't know what to do next. Please let me know how can I insert keyframes to properties in such panel/operators with right click
Best wishes, thank u
