Changing Cycles Shader AOV Data Type does not update nodes socket color
Closed, ResolvedPublicBUG
Operating system: Linux-5.4.0-28-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 435.21
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-04-30 22:07, hash: rB7a809a7504de
Broken: version: 2.82.7 (same system)
Broken: version: 2.82.7 (Windows 10)
It is hard, intermittent or impossible to change the data type (socket color) of Shader AOVs from the Shader AOV box on the View Layer Properties tab, judging from how they appear in the Render Layer node in the Compositor.
Create one or more Shader AOVs. Look at them on the Render Layer node in the Compositor. Try to change their data type.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.May 1 2020, 10:26 PM
Can confirm.
The Type seems to update fine when renaming, but changing the type only indeed doesnt...
Philipp Oeser (lichtwerk) renamed this task from Cycles Shader AOV Can't Change Data Type/Socket Color to Changing Cycles Shader AOV Data Type does not update nodes socket color.May 1 2020, 10:27 PM
Yes, and if you change the name and manage to change the data type that way, changing the name back again reverts the data type, so a certain AOV name 'gets stuck' with a certain data type.
True, a pass just seems to be registered once (and not "re-registered" - if there is even such a thing...)
