Can't even open these files without running into a crash or assert in a debug build when the linked files are found.
Repro:
- Grab
- 02_022A_v022.blend is the main file, open it, and see on the console where it looking for the linked files, place the 2 files in the "expected" location
- Open 02_022A_v022.blend once more,
- Hit the following assert
rna_PoseChannel_constraints_override_apply: Could not find constraint to insert, doing nothing... Stack trace: blender.exe :0x00007FF766A81730 bli_windows_system_backtrace_stack_thread k:\blendergit\blender\source\blender\blenlib\intern\system_win32.c:233 blender.exe :0x00007FF766A807B0 BLI_windows_system_backtrace_stack k:\blendergit\blender\source\blender\blenlib\intern\system_win32.c:320 blender.exe :0x00007FF766A80160 BLI_system_backtrace k:\blendergit\blender\source\blender\blenlib\intern\system_win32.c:383 blender.exe :0x00007FF760F0EA10 rna_PoseChannel_constraints_override_apply k:\blendergit\blender\source\blender\makesrna\intern\rna_pose.c:686 blender.exe :0x00007FF760EF13D0 rna_property_override_operation_apply k:\blendergit\blender\source\blender\makesrna\intern\rna_access_compare_override.c:555 blender.exe :0x00007FF760EF04C0 rna_property_override_apply_ex k:\blendergit\blender\source\blender\makesrna\intern\rna_access_compare_override.c:956 blender.exe :0x00007FF760EEF3C0 RNA_struct_override_apply k:\blendergit\blender\source\blender\makesrna\intern\rna_access_compare_override.c:1025 blender.exe :0x00007FF760569D10 BKE_lib_override_library_update k:\blendergit\blender\source\blender\blenkernel\intern\lib_override.c:948 blender.exe :0x00007FF7605679A0 BKE_lib_override_library_main_update k:\blendergit\blender\source\blender\blenkernel\intern\lib_override.c:981 blender.exe :0x00007FF7609A7BF0 blo_read_file_internal k:\blendergit\blender\source\blender\blenloader\intern\readfile.c:10499 blender.exe :0x00007FF7609EB390 BLO_read_from_file k:\blendergit\blender\source\blender\blenloader\intern\readblenentry.c:320 blender.exe :0x00007FF767C3D870 BKE_blendfile_read k:\blendergit\blender\source\blender\blenkernel\intern\blendfile.c:444 blender.exe :0x00007FF760924590 WM_file_read k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:636 blender.exe :0x00007FF760928060 wm_file_read_opwrap k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2113 blender.exe :0x00007FF760923030 wm_open_mainfile__open k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2255 blender.exe :0x00007FF7609264C0 operator_state_dispatch k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2149 blender.exe :0x00007FF76092B350 wm_open_mainfile_dispatch k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2282 blender.exe :0x00007FF760922D40 wm_open_mainfile__discard_changes k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2197 blender.exe :0x00007FF7609264C0 operator_state_dispatch k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2149 blender.exe :0x00007FF76092B350 wm_open_mainfile_dispatch k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2282 blender.exe :0x00007FF76092B420 wm_open_mainfile_invoke k:\blendergit\blender\source\blender\windowmanager\intern\wm_files.c:2287 blender.exe :0x00007FF760953590 wm_operator_invoke k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:1284 blender.exe :0x00007FF760952210 wm_operator_call_internal k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:1532 blender.exe :0x00007FF7609455F0 WM_operator_name_call_ptr k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:1547 blender.exe :0x00007FF761A00070 ui_apply_but_funcs_after k:\blendergit\blender\source\blender\editors\interface\interface_handlers.c:895 blender.exe :0x00007FF761A21C60 ui_popup_handler k:\blendergit\blender\source\blender\editors\interface\interface_handlers.c:10863 blender.exe :0x00007FF76094F5F0 wm_handler_ui_call k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:622 blender.exe :0x00007FF760950F30 wm_handlers_do_intern k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:2743 blender.exe :0x00007FF76094F9A0 wm_handlers_do k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:2854 blender.exe :0x00007FF76094A380 wm_event_do_handlers k:\blendergit\blender\source\blender\windowmanager\intern\wm_event_system.c:3283 blender.exe :0x00007FF7609209F0 WM_main k:\blendergit\blender\source\blender\windowmanager\intern\wm.c:478 blender.exe :0x00007FF760183E00 main k:\blendergit\blender\source\creator\creator.c:530 blender.exe :0x00007FF767C2E210 invoke_main d:\agent\_work\2\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl:79 blender.exe :0x00007FF767C2DFC0 __scrt_common_main_seh d:\agent\_work\2\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl:288 blender.exe :0x00007FF767C2DFA0 __scrt_common_main d:\agent\_work\2\s\src\vctools\crt\vcstartup\src\startup\exe_common.inl:331 blender.exe :0x00007FF767C2E2D0 mainCRTStartup d:\agent\_work\2\s\src\vctools\crt\vcstartup\src\startup\exe_main.cpp:17 KERNEL32.DLL :0x00007FFD8EBC7BC0 BaseThreadInitThunk ntdll.dll :0x00007FFD8EFCCE30 RtlUserThreadStart
While i can't get as far at the user reporting it, his stack trace is
Stack trace: blender.exe :0x00007FF7115F5E40 pose_channel_in_IK_chain blender.exe :0x00007FF71196CAD0 rna_property_override_diff_default blender.exe :0x00007FF71192A820 rna_property_override_diff blender.exe :0x00007FF71192A140 RNA_struct_override_matches blender.exe :0x00007FF71196EB00 rna_property_override_diff_propptr blender.exe :0x00007FF71196CAD0 rna_property_override_diff_default blender.exe :0x00007FF71192A820 rna_property_override_diff blender.exe :0x00007FF71192A140 RNA_struct_override_matches blender.exe :0x00007FF71196EB00 rna_property_override_diff_propptr blender.exe :0x00007FF71196CAD0 rna_property_override_diff_default blender.exe :0x00007FF71192A820 rna_property_override_diff blender.exe :0x00007FF71192A140 RNA_struct_override_matches blender.exe :0x00007FF711597A10 BKE_lib_override_library_operations_create blender.exe :0x00007FF711597510 BKE_lib_override_library_main_operations_create blender.exe :0x00007FF7140C0140 BKE_undosys_step_push_with_type blender.exe :0x00007FF7140BFF80 BKE_undosys_step_push blender.exe :0x00007FF711C9E290 ED_undo_push blender.exe :0x00007FF711737230 wm_operator_finished blender.exe :0x00007FF711735270 wm_handler_operator_call blender.exe :0x00007FF7117361F0 wm_handlers_do_intern blender.exe :0x00007FF711735820 wm_handlers_do blender.exe :0x00007FF711732EA0 wm_event_do_handlers blender.exe :0x00007FF71171E9A0 WM_main blender.exe :0x00007FF7114AA530 main blender.exe :0x00007FF7140B8548 __scrt_common_main_seh KERNEL32.DLL :0x00007FFBE2E17BC0 BaseThreadInitThunk ntdll.dll :0x00007FFBE4B8CE30 RtlUserThreadStart
which also seems to point at something in the override system
Original Report
Graphics card: GeForce GTX 1070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.59
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
In a specific file (and older versions of the same scene), whenever I do almost anything, including moving the timeline, selecting an object in the outliner, saving the file, and switching scenes (among other normal blender activities that I lost count of), the program will instantly crash. When I run in debug mode, all it says in the console when crashing is EXCEPTION_ACCESS_VIOLATION. The file has a linked rig from another file. In similar files, I will commonly get the same error when I turn off the object visibility in the outliner.
I can't get this to reproduce elsewhere consistently, it all happens very random.
- Get a file with a linked rig+mesh
- Turn the object visibility off and on in the outliner
- if that doesn't make it crash, move the timeline around
- if that doesn't crash, try save as...
- if that doesn't crash, try anything else
This is a really random bug and I can't figure out how to reliably reproduce it outside of this specific file. I cannot send the file because I work under NDA.
