Operating system: Linux-5.4.35-1-MANJARO-x86_64-with-glibc2.29 64 Bits
Graphics card: AMD CAICOS (DRM 2.50.0 / 5.4.35-1-MANJARO, LLVM 10.0.0) X.Org 3.3 (Core Profile) Mesa 20.0.5
Broken: version: 2.82 (sub 7), branch: makepkg (modified), commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Blender crashes when I try to change the cycles render output file path. The output path will not change and it will not accept an output file name change either. Using the Preferences to directly set up an output file path also crashes. Its seems that any way I try to change the output file path it will fail and crash.
- Clearing the cache did not help; I do not believe that too little memory is the problem here, but really don't know either way what has gone wrong.
- This is a "new" crash problem that did not happen in any previous version of Blender, nor in any of my renderings with 2.82 up until just recently. Something changed at the last software update that I am not able to identify.
- THIS IS THE CRASH .txt FILE ---
Blender 2.82 (sub 7), Commit date: 2020-03-12 05:06, Hash 375c7dc4caf4
bpy.context.space_data.context = 'OUTPUT' # Property
bpy.data.window_managers["WinMan"].(null) = True # Property
bpy.context.space_data.recent_folders_active = 1 # Property
bpy.context.space_data.params.filename = "test" # Property
backtrace
blender(BLI_system_backtrace+0x34) [0x55b2825e0a34]
blender(+0xed6cf5) [0x55b280346cf5]
/usr/lib/libc.so.6(+0x3bd70) [0x7f8f1bc97d70]
/usr/lib/dri/r600_dri.so(+0x66fc4a) [0x7f8ef0d50c4a]
/usr/lib/dri/r600_dri.so(+0x7a247b) [0x7f8ef0e8347b]
/usr/lib/dri/r600_dri.so(+0x7a24b2) [0x7f8ef0e834b2]
/usr/lib/dri/r600_dri.so(+0x13572a) [0x7f8ef081672a]
/usr/lib/dri/r600_dri.so(+0x137553) [0x7f8ef0818553]
/usr/lib/dri/r600_dri.so(+0x143156) [0x7f8ef0824156]
/usr/lib/dri/r600_dri.so(+0x140176) [0x7f8ef0821176]
/usr/lib/dri/r600_dri.so(+0x131fcb) [0x7f8ef0812fcb]
/usr/lib/dri/r600_dri.so(+0x370f7d) [0x7f8ef0a51f7d]
/usr/lib/dri/r600_dri.so(+0x371034) [0x7f8ef0a52034]
blender(immEnd+0x2da) [0x55b2824d372a]
blender(ED_region_do_draw+0xbc9) [0x55b280833039]
blender(wm_draw_update+0x4bf) [0x55b280507ecf]
blender(WM_main+0x34) [0x55b280505e14]
blender(main+0x344) [0x55b280318154]
/usr/lib/libc.so.6(__libc_start_main+0xf3) [0x7f8f1bc83023]
blender(_start+0x2e) [0x55b2803430fe]
I really like Blender, and I do not want to lose this tool! Please help. Thank you!
Blake
