Armature Deform parenting option doesn't work with Grease Pencil objects
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Parenting a pre-painted Grease Pencil object to Armature doesn't work.
Create new project
Create GP Object, draw 2 squiggles, create 2 vertex groups, assign each squiggle's verts (weight of 1) to each separate group. (Same as creating VG before drawing squiggles with Add Weight Data enabled)
Create Armature with 2 bones named the same way as the vertex groups.
Set Armature as GP's parent with Armature Deform
Moving bones in pose mode doesn't move the squiggles.
This works however if I use With Empty Groups which makes no sense compared to when you rig a mesh.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 5 2020, 11:17 AM
Just to make sure we are all on the same page:
could you please share your .blend file just before step
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.May 5 2020, 12:18 PM
Can confirm, checking...
