Only Insert Needed breaks manual keying.
Closed, DuplicatePublic
Broken: all since 2.7x
Worked: never
Only Insert Needed option in animation preferences, overrides manual keying hence making manual keying unusable.
Select your default cube,
create a keyframe in frame 1
create a keyframe in frame 10
go to preferences > animation
activate the Only Insert Needed option.
go to frame 5, try inserting a keyframe with, I (menu) or in the animation editors.
message comes up: "Keying set failed to insert any keyframes"
this makes the option needed to be turned off everytime that you want to force a keyframe which is broken.
any further info let me know.
