Viewport Overlay "Outline Selected" make grease pencil stroke partially change color on Move/Rotate/Scale
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: NVIDIA GeForce GTX 680MX OpenGL Engine NVIDIA Corporation 4.1 NVIDIA-10.32.0 355.11.10.10.40.102
Broken version: 2.90 (sub 0)
Broken version: 2.83
Worked version: 2.82a
Viewports Overlay Outline Selected make grease pencil stroke partially change color on object mode Move/Rotate/Scale
(invisible on a white background depending on the scale)
  1. open the file
  2. select the stroke
  3. press G
Notice that the stroke partially change color on blender 2.90
on 2.90
on 2.82a
dupoxy (dupoxy) added a comment.EditedMay 6 2020, 4:15 PM
Ok so this is maybe not really a bug.
I found that you could change the color in preferences >themes > 3d viewport > Transform
maybe change the default of this color to non white ?
Antonio Vazquez (antoniov) closed this task as Resolved.May 6 2020, 8:24 PM
Antonio Vazquez (antoniov) claimed this task.
Why don't try to change the background color of the viewport?
Thanks for the report, but as this is not a bug of grease pencil. I think is better to close it and if you need, open a new one with the theme color problem. If it's needed in the future, we can reopen this task.
dupoxy (dupoxy) added a comment.EditedMay 6 2020, 8:41 PM
Yes, you're right, changing the background color of the default 2D Template can also be an option.
Thank you
