2.82a & 2.83 beta - Segfault when loading textures
Closed, DuplicatePublic
Operating system: Linux Fedora 32
Graphics card: Radeon RX Vega 64 (VEGA10, DRM 3.36.0, 5.6.10-300.fc32.x86_64)
Broken: 2.82a
Blender crashes immediatly after trying to load an image texture (27mo .jpg) with the following console output :
Read prefs: /home/martin/.config/blender/2.82/config/userpref.blend
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
Writing: /tmp/blender.crash.txt
Erreur de segmentation (core dumped)
Open Blender (factory settings), switch to the Shading workspace OR go to the Material tab in the Properties panel, add an Image Texture node, click Open then load an image texture.
The crash happens 99% of the time, although it seems that loading up the texture from the Properties panel works more often.
Thanks a lot !
