Sculpt mode: no damaged vertices on mouseclick
On blender versions 2.44 through 2.45 (official & svn) - both static and normal, the sculpt tool fails to work. In any case (simplest being a plane), when I click, nothing will happen - apart from the occassional affecting wrong vertices.
I guess it's a very setup-specific thing: there are only a handful of people with this problem, at least that posted on elysiun: http://blenderartists.org/forum/showthread.php?t=94852 .
I know I'm supposed to tell you how to reproduce this (which would be; try to sculpt), but unless you get the exact hardware - which next to a financial challenge also possibly poses a physical one, regarding the motherboard (if you need the specific modelnumber, I'll look it up somehow)..
Abit motherboard with Intel ICH8 chipset
with Intel Core2Duo 1.86@1066FSB, 2GB RAM@1066FSB
Nvidia 8800 GTS with G80 gpu
Debian GNU/Linux testing, linux 2.6.21
so I'll tell you what I know :/
What exactly happens when I click isn't clear to me, but when an extreme angle is taken to the object (be it a plane, cube, suzanne or whatever), vertices *might* start to move - however, seldom the ones that are under the cursor, and never with the appropriate 'fade'.
I have been nibbling on the code for a bit, so I'm able to tell you this:
In sculptmode.c, inside the function do_brush_action, on line 936 (SVN version from 29/10/2007), inside a if-for construction where the vertices within reach are being calculated for damage, there's a
if(av_dist < e.size) {
and the code never gets past that calculation, which primarily compairs the editdata object, and some unproject()-results. As is probably clear by now, I don't at the least know what I'm talking about, but I'm willing to help, so I had to try at least :p ..
I've replaced this line with if(1) { to see what happens, and in fact it goes 'well' - it just returns a fade of 0.00000000. So I'm guessing, somewhere in the calculation of matrixes & vectors.. & stuff.. stuff goes wrong. Ahem.
I'd really like to give you guys more information, but I wouldn't know *what kind* of information, because I just dont know what could screw up matrices like that. For example, I'd like to 'draw' the editdata object that init_editdata generates, or at least the .center of it, so I could 'see' what blender is doing. Of course, that is not effective programming, but what do I know eh :p ..
(In case you were wondering how much I've tried, for example, clicking the 'other' LMB:
I've tried every setting I could think of, tested the tablet input (wasnt doing anything, which is good), removed my .B.blend & ~/.blender, reinstalled all my graphic drivers, used the nv-driver to assure myself GL was being done with software, etc. Running the windows version via wine yielded the same result.
To my knowledge, the only things I havent changed are described in my setup, above.)
So now, I'm completely stumped here, because apart from the video card I've got a fairly common setup. I really, REALLY, LOVE!! your tool, it's frigging awesome, to say the least - thanks a lodylodylot!; so if you need any help at all, even with simple things as scanning the code for.. little GL-devils or whatyacallit.., just PM me! (Assuming that's possible here, I just registered - otherwise, you could use roderik@gmail.om)
P.S.: Sorry for the messy report; I might have exaggerated my attempt to leave more than just 'sculpt mode doesnt work'...
whoops, my email address is wrong. Use roderik _at_ digicit.nl.
If your nickname is Nicholas Bishop, please read this ;p
Nicholas is not much available at the moment...
What I do know is that proper sculpting depends on opengl to work flawlessly. Try to set or disable everything you can find in our system to test? Further:
- is Blender 2.43 working for you? Or older? (Only official releases from blender.org)
download.blender.org/release/
If older versions don't work either, you got a system problem... :)
- load the static version of blender for linux, and test.
if that version does work, you got issues with opengl drivers.
Well, like I said, the static version doesnt work either: i even tried the nv X.org driver, which doesnt even have hardware support for OpenGL; i tried all different kinds of software OpenGL xorg binaries; and last but not least, older versions dont work either.
So apparently, I've got a system problem.. But what does it mean? What kind of system problem could it be, and/or how can i find out?
Or is it more like - it's a hardware quirk, and you can say goodbye to your dreams of ever sculpting again :P?
Also, will Nicholas Bishop be back after 6 dec. :P? I'd sure like to be able to get some more information, because right now there isn't a thing I can do to find out more..
Let me clarify my intentions - I will keep trying to make it work, doing whatever I can think of. The pool of things I can try however has dried up to a dash of dust - as this problem seems to be caused by OpenGL, but also occurs under nv & static/mesa, I'm confused as to what area I should tweak now.
I'm not deep enough into C & OpenGL programming (I'm a PHP programmer :S) to find the actual cause, but with a little help from your side - as to what I could be looking for, if not an OpenGL problem then what? - I think I'd manage it.
Ultimately this could result in a small P.S. in the blenderwiki at sculpt mode with a little bit of text information saying something like: "If your sculpt mode does not seem to react on clicks, try " and then whatever the solution will be in this case. I'm still hoping it could be a library, but I've had all the OpenGL libraries and I'm using a standard Debian distro. All in all, I want to nail this problem, but I can only do so if/when you guys tell me roughly in what direction to aim ;p
Thanks for listening/helping/coding this awesome program ;D
Possible fix.
I was also suffering from the same problem. After a couple of bumps I was able to solve the problem.
Under Debian, with libGLU >= 7.x Blender sculpt tool doesn't work.
To fix this I downgraded the package libglu1-mesa-7.0.1 to libglu1-mesa-6.5.1.
I don't know if this is an intentional change on the GLU libs or if they messed up something. In any case, either libGLU or blender is gonna need a fix to work in the future.
I'm still waiting for confirmation on this from scraze. But if this also solves his problem, I leave the rest to the dev teams :)
Thanks for everything.
Renato Alves' solution works for me too!
The new mesa-libs (which I apparently forgot to tweak in the downgrade-direction Dx) will apparently not gluUnproject right.
I don't know if the new libglu1-mesa needs other types of variables passed to it or that it's simply gone crazy - so I guess I'll go ask the mesa-guys and come back here with some kind of answer ;D . If there is something that needs to be changed, I guess you should know :?
Thanks all!
Well, it seems to be a genuine libglu1 mesa bug, but only in the debian archives. Apparently it has been fixed a version later (in 7.0.2).. See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=449490
So this can be closed! Sorry to annoy you guys ;p
I'll put the solution in the thread on BlenderArtists I mentioned, and that'll be that.
Thanks again!
great, one more issue solved!
(move to opengl tracker for future review)
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:37 AM
