Compositor Output Path Broken
Edit by @Alaska (Alaska)
T77065#938570
The file output node is working as expected making this report invalid. However, as a design question, what's the possibility of the file output node auto correcting something like //6/a to //6/a/ to avoid the issue described in the original post.
OS: Ubuntu 20.04 LTS
Blender: 2.90 0270941b70d5
  • Output images of the compositor always begin with Image, e.g. //6/Image0001.png
  • Even if the path does not end with a slash, e.g. //6/hello, the compositor still outputs in //6/hello/Image0001.png
Expected behavior: copying the behavior of the Output properties panel
//6/ -> //6/0001.png not //6/Image0001.png
//6/a -> //6/a0001.png not //6/a/Image0001.png
Broken both with GUI and with terminal rendering
Alaska (Alaska) added a subscriber: Alaska (Alaska).
The file output node is working as expected. This is more of a design question. I have updated the task to reflect this:
Explanations of things:
To change the name of your file when exporting from the file output node, open the side bar N and with the file output node selected change the name of your file here:
To the developers. What's the possibility of seeing the file output node auto complete something like //6/a to //6/a/ to avoid this confusion.
Alaska (Alaska) updated the task description. (Show Details)
I think a less hidden way of showing the information would be to rename "Base Path" to "Base Folder"
Thanks for the report, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
