Operating system: Windows-10-10.0.14393-SP0 64 Bits
Graphics card: Radeon RX 560 Series ATI Technologies Inc. 4.5.13521 Core Profile Context 24.20.11021.1000
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
The material of the object will turn black (shadeless) when the node tree is plugged into the height input of the bump node. Error is somehow related to the nodegroup "Paint Chipping 1" (NodeGroup.155) and can be circumvented by muting some of the nodes, such as the image texture and the two voronoi textures on the left end of the nodegroup or the last node within the "Height" frame, which is plugged into the bump node.
More detailed description can be found in this blenderartists thread: https://blenderartists.org/t/node-tree-for-normal-input-randomly-outputs-black-material-for-no-apparent-reason/1228394
(Problem has occured multiple times with different materials, always relating to a node group with and image texture, plugged into a node tree connected to a bump node and any shader.)
Open attatched blend file and enter viewport render mode (Cycles). Once rendered, object will appear black. Mute the last blue node in the node tree and the material will start rendering.
