Join Malfunction
My Powerspec PC INFO
Device Speifications
Device Name: CurtisAMay-PC
Processor: Intel(R) Core(TM) i3-4340 CPU @ 3.60GHz 3.60GHz
Graphics: Intel(R) HD Graphics 4600
Installed RAM: 16.00 GB (15.83 GB usable)
Device ID: F7193C75-337F-44BE-A446-4A125F371E44
Product ID: 00330 80000 00000 AA039
System Type: 64-bit operating system - x64 based processor
Pen & Touch: No pen and touch is available for this display
Windows Specifications
Edition: Windows 10 Pro
Version: 1909
Installed On: 2/22/2020
OS Build: 18363.778
Support
Manufacturer: Micro Electronics Inc.
Phone: (614) 850-3670
Website: https://www.microcenter.com
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
when I try to join mirror images one gets larger and distorted.
in edit mode I deleted half of the head, in the object mode I duplicated the half head and mirrored it on Y axis, I placed the two halves together and tried to join the two halves together. the result was the original half grew bigger and distorted.
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.May 30 2020, 5:21 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Are you able to provide the .blend file for us to investigate?
yes, here it is Imm3.blend
Actually, looking at the image, it seems the issue is most likely caused by the solidify modifier. If I was to take a guess, the normal of one side of the head are backwards. In edit mode, select the part of the head that grows when you join the two and press Alt+N then select Flip. Hope this helps.
Alaska (Alaska) closed this task as Archived.EditedMay 30 2020, 5:33 AM
Alaska (Alaska) claimed this task.
Yeah, looking at the file the issue is your normals.
This is not a bug with Blender. I will close this report.
The exact steps for fixing this are as follows:
  1. Select the right side of the face.
  2. Press Ctrl+A and select Scale.
  3. Enter edit mode on the right side of the face.
  4. Press A.
  5. Press Alt+N and select Flip.
  6. Go back to object mode and select the left side of the face.
  7. Press Ctrl+A and select Scale.
  8. Select the left side of the face then the right side of the face.
  9. Join the two with Ctrl+J.
  10. Play around with the settings in the solidify modifier until you get what you like.
