2.82 Invoking Script Subprogram in a Group Subprogram Crashes Blender
Closed, DuplicatePublic
T77317, T77323, T77327 are the same issue
System Information (See attached)
Operating system: Windows 10
Graphics card:
Broken:
version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: 375c7dc4caf4, type: Release
build date: 2020-03-12, 15:41:08
platform: Windows
Because the Object Instancer Node cannot be executed within a Animation Nodes SubProgram I created two Python scripts that:
  1. Creates a plane from a mesh and add adds modifiers
fltWallsInnerDiameter = 1.2
fltResolution = 50.0
bpy.ops.mesh.primitive_plane_add(size=fltWallsInnerDiameter, \
enter_editmode=False, location=(0, 0, 0))
bpy.ops.object.editmode_toggle()
bpy.ops.mesh.subdivide(number_cuts=fltResolution)
objWater = bpy.context.active_object
objWater.name = "Water"
  1. Create a cylinder from a mesh and adds modifiers
When I run either script manually, the objects are created just fine.
Whenever I try to invoke the python (script) subprogram within a Group SubProgram Blender crashes. And if I am able to save the .blend file, Blender crashes when I try to reload it.
The objects need to be created 'on the fly' based on dimensions that are user-provided. It is not clear why Blender will not run a python script that creates objects within a subprogram.
To reproduce the error, in the attached file insert the pytWaterCreateRun subprogram into the Animation node, and run the animation. Blender just totally goes away.
