Crash in eevee & cycles material preview mode; and in eevee rendered mode.
Operating system: Win10 64
Graphics card: GTX 1070
Broken: 2.83
Worked: 2.82
Scene crashes in EEVEE Material Preview or Render View mode, in Cycles crashes in Material Preview but not in Rendered view mode.
Not sure if it is for all files, I opened my old file, changed to Material Preview, crashed.
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.EditedJun 4 2020, 6:44 PM
There are many lines about your addons.
  • Close Blender,
  • rename the Blender Foundation folder at C:\Users\Rapha\AppData\Roaming\Blender Foundation\ to something else
  • reopen Blender, don't import any previous settings if it asks.
  • redo the steps of crash
Also update the GPU drivers.
Ankit Meel (ankitm) renamed this task from EEVEE crashing to Crash in eevee & cycles material preview mode; and in eevee rendered mode..Jun 4 2020, 6:45 PM
Does it happen on default cube too ?
I haven't tested it yet, but probably not, but I'll report if it does
It's something particulary wrong with this model.
I'm not a master in Nodes setup, BUT it was working in previous versions, so...
I've hidden the characters and scenario one by one and found out that only Mario crashes for some reason, while Luigi have a similar node setup, it doesn't crash.
Here's Mario for testing: (I'm working on a fan art)
Ankit Meel (ankitm) added a comment.EditedJun 5 2020, 9:01 AM
It's hitting the assert in BKE_mesh_wrapper_minmax
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/mesh_wrapper.c$164
Looks like such case should never happen.
But since 2.82a worked & the file was addd in rBdeaff945d0b9, I'll confirm it if @Raphael Catossi (RCatossi) you could remove all extraneous elements from the file and upload a minimal file to test redo the bug.
My apologies, the same error happens in 2.82 even in 2.81.16 ...
I guess I'll have to re-work on those nodes...
