Flickering and strange arttifacts when entering edit mode
Closed, DuplicatePublic
Operating system: windows 10 pro
Graphics card: intel HD graphics card
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
bender version 2.83
When i enter edit mode the screen starts to ficker and then itt enters edit mode with artifacts on tthe default cube
open blender
then go to LAYOUT tab and hit TAB to enter edit mode
or
click on modeling tab{F8577631}
Alaska (Alaska) added a subscriber: Alaska (Alaska).
At the moment, a work around is to turn off anti-aliasing in the user preferences.
  1. Select from the top of Blender select Edit>Preferences.
  2. Navigate to the Viewport tab.
  3. Change "viewport anti-aliasing" to Single pass or No anti-aliasing.
