In edit mode selection and deletion operation randomly stop working
Operating system: Windows
Graphics card:MX150
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Blender Version: 2.83
sometime in edit mode selection and deletion operation stop working then we have to do undo to fix it and also mouse is stop working too many times approx 15 times in just 10 min.
based on default startup
Ankit Meel (ankitm) renamed this task from edit mode to In edit mode selection and deletion operation randomly stop working .Jun 5 2020, 10:04 PM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Needs Information from User.Jun 8 2020, 3:59 PM
We need steps to reproduce the problem.
Also, can you try the latest daily build? https://builder.blender.org/download/
Thanks for the report. If the problem persists please open a new report with the required information.
