Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.20
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-06-04 22:58, hash: rBc7329da14b22
Worked: 2.90 Alpha 2020 - 06-02
When using custom modal operator, auto save causes crash:
The custom modal {F8584443}operator does not crash when auto save disabled.
Crash Log:
Info: Saved "Waneella_33.blend"
Skipping auto-save, modal operator running, retrying in ten seconds...
Memoryblock free: pointer not in memlist
running modal
Scaling
Applying Scale
running modal
Scaling
Memoryblock Chunk buffer: double free
custom modal operator is attached, if you are in modal mode while autosave happens, the Memoryblock errors start showing. Does not crash on first autosave but eventually will crash with too many memoryblock errors.
