Failure to understand. How DO I DELETE THIS?!
r
Collin (cyear) renamed this task from Node wrangler shortcut SHIFT+CTRL+T to import texture fails to load them. Throws up error. to Failure to understand. How DO I DELETE THIS?!.Jun 6 2020, 4:40 AM
Collin (cyear) updated the task description. (Show Details)
Xing Liu (xing) changed the task status from Needs Triage to Needs Information from User.Jun 6 2020, 4:47 AM
Xing Liu (xing) added a subscriber: Xing Liu (xing).
What are you trying to delete?
Alaska (Alaska) closed this task as Archived.Jun 6 2020, 4:55 AM
Alaska (Alaska) claimed this task.
Alaska (Alaska) added a subscriber: Alaska (Alaska).
This report does not contain all the requested information, which is required for us to investigate the issue.
For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think you found a bug, please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
