Operating system: Linux (debian bullseye)
Graphics card: Nvidia Geforce GTX 1070
Broken: 2.90 alpha, fd14d1ccebd4, master, 2020-06-12
Worked: never (tested also 2.83 official build)
If the voxel size of the voxel remesh modifier is at 0.00001, blender will crash with the error message (in terminal)
terminate called after throwing an instance of 'openvdb::v7_0::ArithmeticError' what(): ArithmeticError: Non-zero scale values required
Based on default startup
- Go into edit mode of the default cube and scale it down by 0.0001
- Exit editmode and add a voxel remesh modifier
- Set the voxel size to 0.00002 (it should give the corresponding result)
- Set the voxelsize to 0.00001 (crash, see console for error message)
