Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 24.20.100.6194
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Worked: Blender 2.82
Blender crashes immediately when you access "Material Preview Mode" or "Render Preview Mode", else textures are purple.
Use the default Cube scene.
Go to the Shader Editor and appended an Image Texture node to the default material. I dragged in a JPG called "testmap.jpg".
Connect this node to Base Color.
Return to 3D Viewport.
Try to use the "Material Preview Mode". The block will be purple or Blender will crash.
Try to use the "Render Preview Mode". The block will be purple. show the texture correctly, or crash.
