Blender 2.83 latest Fire alpha not displaying properly in viewport or render
Closed, DuplicatePublic
Operating system: Windows 10 Pro
Graphics card: AMD RX580 8G
Broken: 2.83 Master from splash screen latest version
Worked: none of the builds. from 2.79 till 2.83 were consistently bad. It seems to be sort of random
When I go render my smoke sim with fire + smoke or just fire the alpha channel works different in the viewport than in the final render. There is a thread on reddit about this but it doesn't really fix the issue for me. I have found that when I use flame instead of heat for the fire the issue becomes less apparent. Then when I use a set alpha node in the compositor the issue goes away but then there is no alpha channel anymore. When I use another alpha node after that with the alpha pass(?) plugged into it I get the same issue. I have created an workaround for it by making my own alpha channel and then clamping it.
Exact steps for others to reproduce the error See the above.
