Operating system: windows 10 prof. 64-bit
Graphics card: 1650 4gb
Broken: (2.83 cycles engine)
Worked: (2.83 eevee engine)
Blender was downloaded from STEAM
I made a simple scene with smoke simulation (MANTAFLOW). After I baked the simulation, and checked in render view under cycles engine it worked well. After I tired to render a simple 1920x1080 image (with 32 render samples render volume 0.075, step size:1024.) the objects rendered well, but the smoke did not. I shift to CPU rendering (CPU type: i7-9750h 6 cores 12 threads) it works well, but under OpenCl again fail. Under EEVEE engine it rendered well.
How can I solve the problem, or it will be fixed in the future?
Thanks
I used a 250 sample cache, all other included in *.blend file. Cache file type: OpenVDB, with final type.
