Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Worked: na
When rendering a fluid sim using Optix on the GPU cycles crashes at frame 195 when I try to render. Resumed render from frame 198 and have not encountered the issue. I cannot see anything different about this frame. Turning off addons or experimental features does not seem to change the error I thought it may be a memory issue from persistent images/fluid, though it seems not. I have encountered a few other mild bugs while experimenting with mantaflow, such as inability to bake in modular mode. Thank you, Tom
render as animation from frame 195 on GPU with optix.
