Graph Editor Handles Broken
Don't know
I am using 2.83.0
When I am trying to edit the curves in the graph editor, I grab the handles and move them them around,but instead of the curve to change, the key-frames move around without the curve changing. I tried to press R to rotate but that doesn't work.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jun 24 2020, 10:09 AM
Cannot reproduce here.
Please provide a simple example .blend file that shows this issue (maybe a video of what happens might help here as well)
Please also make sure you provide System information (attach the output of Help > Save System Info as a txt file here).
Another thing to test is if this also happens with Factory Default (File > Defaults > Load Factory Settings)
Philipp Oeser (lichtwerk) closed this task as Archived.Jul 6 2020, 10:37 AM
