Operating system: windows 10
Graphics card: GeForce GTX 970
Broken: 2.83
Worked: Not found: 2.82a gives another wrong result (pink rectangle instead of image)
When a video clip is used as a background image for cameras, in the 3D scene, a property named Proxy Render Size appears in the Camera Background Images panel. It is supposed to allow the user to use a low resolution of the video. when changing the value of this parameter - From full or 100% (difference?) to 25% we should see in the viewport a degradation of the image quality (more pixelised). In practice nothing changes, whatever the value.
Based on the default startup or an attached .blend file:
- Create a camera and select it.
- Go to the Data Properties panel, in the Background Images subpanel clic on the button Add Image, then on the button Movie Clip.
- Clic on the button Open to open a file browser, get a video clip (I used a .mp4 of res 1280 x 720, provided in the zip file)
- Set the camera as the active view in the 3D Viewport and display the background. It should appear at 100% quality.
- Now change the proxy Render Setting value to 25%. Nothing changes in the scene, the quality of the video is the same. The experted behavior is to see a more pixelized image.
- If you jog into the timeline the quality is still the high res one. If you save and reload the file then on other values than 100% you get flashing pink rectangles instead of the expected proxy.
Save System Info file is provided in the Zip file.
Thank you
