version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: 211b6c29f771, type: Release
build date: 2020-06-03, 12:41:58
platform: Windows
binary path: 'C:\\Program Files\\Blender Foundation\\Blender 2.83\\blender.exe'
build cflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP /bigobj -openmp
build cxxflags: /W3 /w34062 /w34115 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /wd4661 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc /bigobj /permissive- /Zc:twoPhase- -openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152,70656 /INCREMENTAL:NO /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Operating system:
Graphics card: 2 x GTX 1070
I hit undo and instead of going back one step, it goes back a lot longer.
I've been working on a scene and using some fairly repetitive steps, so I'll mention the typical steps I've taken.
I'll import a model, say an fbx, work on the materials, move it into place etc. then if I hit undo (shortcut), Blender goes into edit mode (even though I wasn't in edit mode) and reverts back to about an hour ago (I'm guessing it reverts to last saved). The model I imported is gone and any recent changes made are also absent.
There are other complications to this bug that I can't fully explain, but the main characteristic is that when I undo, it goes into edit mode and the history of undo's becomes confused and conflicted with the edit mode undo's.
Also worth noting that while hitting CTRL+Z seems to revert, the revert function doesn't work in the file menu.
Attached the file minus the contents (as the scene would be heavy) as well as the system info text file.
